Relearn CVT-ja
Šulrčk
Prispevki: 13
Pridružen: 11. Oktober 2018, 19:16
Relearn CVT-ja
Odgovor Avtor: Šulrčk » 17. November 2025, 08:39
Živjo vsem
Ali imamo kakšnega mojstra na dolenjskem ali v posavju, ki bi bil tako dober in mi prišel naredit relearn CVT-ja na Outbacku l.2010 (tip menjalnika je TR690). Sem iz okolice Sevnice.
Menjalnik je bil razstavljen in sestavljen nazaj skupaj, zdej bi ga bilo pa treba priklopit na računalnik in narediti relearn.
Hvala vsem za odgovore :vctry
LP Benjamin
Prispevki: 2461
Re: Relearn CVT-ja
Odgovor Avtor: ijuvan » 19. November 2025, 12:09
Pa je potreben softwarski relearn, ali se sam nauči med vožnjo?
Jaz sem na TR580 zamenjal olje v menjalniku in ponekod piše, da je potrebno iti čez softwarski postopek, ampak pri meni ni bilo časa. Se že vozim par tisoč kilometrov in mi deluje OK.
Re: Relearn CVT-ja
Odgovor Avtor: nebivedu » 19. November 2025, 14:09
Ročni postopek brez računalnika (jaz sem po tem delal, ko smo zamenjal en "valve body":
1. Turn off all lights and accessories (no A/C, lights, blower, radio, etc.).
2. Disconnect battery for 30 min.
3. Push brake couple of times.
4. Re-connect battery.
5. Turn key to ON position for 30 seconds (throttle body has a chance to go through a check sweep during this period; do not let engine turn over).
6. Start car and let it idle without any load (no A/C, lights, blower, radio, etc.).
7. Leave engine running for 10 minutes, never loading, never touching accelerator.
8. Turn off engine and leave key in off position for at least 30 seconds.
9. Turn key back to the ON position for 30 seconds without starting engine.
10. Start engine and leave idling for 5 minutes without loading or touching accelerator.
11. Turn off engine and wait 20 seconds before restarting.
12. Go for a drive.
Imaš pa še 2 načina:
Re-connect battery.
Turn key to ON position for 15 seconds (throttle body has a chance to go through a check sweep during this period; do not let engine turn over).
Turn off engine and leave key in off position for at least 20 seconds.
Turn key back to the ON position for 15 seconds without starting engine.
Go for a drive.
Disconnect battery.
Put foot on brake for 10 seconds (drain electrical system).
Reconnect battery.
Turn ignition to "ON" position.
Turn ignition "OFF".
Wait 15 seconds.
Start car.
Idle for 60 seconds.
Drive for 30 minutes on light/moderate throttle.
T-Man
Prispevki: 82
Pridružen: 08. November 2021, 10:59
Re: Relearn CVT-ja
Odgovor Avtor: T-Man » 19. November 2025, 21:11
Jaz bi se v primeru, da je bil menjalnik razstavljen in sestavljen kot piše avtor teme, vsekakor lotil relearn-a z softwarom. Treba ga je narest pri določenem temperaturnem obsegu, da se zagotovi pravi nivo olja itd.
Kar pa Igor piše bi pa uporabil za 'idle relearn'.
Šulrčk
Prispevki: 13
Re: Relearn CVT-ja
Odgovor Avtor: Šulrčk » 20. November 2025, 18:57
T-Man napisal/-a: ↑
Točno tako
Šulrčk
Prispevki: 13
Re: Relearn CVT-ja
Odgovor Avtor: Šulrčk » 03. December 2025, 18:47
Tole bo rešilo moj problem
"https://filefa.st/yKNWm/img-20251201-163415.jpg"
Če bi kdo rabil "šarit" po software-u me pocukajte 😉
Š.
Topo
Prispevki: 416
Kraj: Nova Gorica
Re: Relearn CVT-ja
Odgovor Avtor: Topo » 09. Januar 2026, 14:09
Slike se ne vidi več. Kaj si nabavil?
