Avtomatsko uravnavanje višine žarometov
V četrtek smo veselo rili po 30cm pršiča in od takrat obe xenonki svetita prenizko. Senzor na zadnji premi je priklopljen in zgleda nepoškodovan, ob teh temperaturah se je tudi odtajal. Forester SH 2010, zadaj stabilizatorji za uravnavanje višine, avto zgleda v vago. Kakšna ideja?
- Prispevki: 4480
Re: Avtomatsko uravnavanje višine žarometov
Kaj pa senzor spredaj?
Z modelskim letom 2010 imajo samo zadnji senzor.
Sicer najbrž malo verjetno, ampak ali bi lahko fasal slanico v kak konektor? Če bi snel konektorje in malo z wd40 (ali s kako še bolj primerno snovjo) to mal prešprical? Ali pa izmeril na konektorju, če senzor še pravilno deluje?
- Prispevki: 4480
Poskusi tole:
2. REINITIALIZATION
1) Bounce the vehicle several times to normalize the suspension.
2) Make certain that someone is seated in the driver’s seat.
3) Turn the ignition switch to ON, and, within 1.5 — 10 seconds, turn the headlight switch OFF ⇒ ON five or more successive times.
4) Check that the headlight beam drops once, then returns to normal.
5) Within 30 seconds of confirming step 4), turn the ignition switch to OFF.
6) Turn the ignition switch to ON again, and, within 1.5 — 10 seconds, turn the headlight switch OFF ⇒ ON five or more successive times.
7) Make sure that the indicator in the meter flashes three times and then turns OFF, indicating that reinitialization has been successfully completed. (At this time, the headlight beam lowers once and returns to the original position.)
8) Perform headlight beam adjustment. <Ref. to LI-19, ADJUSTMENT, Headlight Assembly.>
CAUTION:
If the indicator does not flash three times or the headlight beam does not operate, it can be as- sumed that there is an open circuit or faulty wiring in a harness of the headlight beam leveler control module, front/back vehicle height sensors or headlight assembly. Always perform initialization or reinitialization after checking or repairing according to check procedures. <Ref. to LI-13, INSPECTION, Auto Headlight Beam Leveler System.> <Ref. to LI-16, PROCEDURE, Auto Headlight Beam Leveler System.>
Evo še povzetek, crknil je senzor, naročil sem original mehanizem s senzorjem, najugodnejši je bil iz Litve, samo za kitajsko kopijo senzorja se nisem odločil saj je bila zarjavela cela vagica in se je premikala na vijakih namesto na ležajih. Danes zvečer imam spet normalno višino žarometov. Hvala za pomoč.
