Diagonal Viewing Size: 73.02 cm / 29 inches (28.75 inch wide viewable image size)
Active Display Area (H x W): 672.77 x 283.82 mm / 26.49" x 11.17"
Optimal resolution: 2560 x 1080 at 60 Hz
Aspect ratio: Ultra widescreen (21:9)
Pixel pitch: 0.09 (H) mm x 0.26 (V) mm
Brightness: 300 cd/m² (typical), 50 cd/m² (minimum)
Adjustability: Height-Adjustable stand, tilt, swivel and built in cable-management, capacitive touch OSD controls
Color Support: Color Gamut (typical): sRGB >99%, 82% (CIE 1976)4
Color Depth: 16.7 million colors
Contrast Ratio: 1000 to 1 (typical), Dynamic Contrast Ratio: 2 Million:1 (Max)
Viewing Angle: 178° vertical / 178° horizontal
Response Time: 8ms (grey to grey)
Panel type, surface: In-plane switching, anti-glare with hard coat 3H
Backlight Technology: LED
Display Type: Widescreen Flat Panel Display
Flat Panel Mount Interface: VESA
Display Screen Coating: Antiglare with hard-coating 3H
Audio Output: DC power connector for optional Dell Soundbar
1 Dual Link Digital Visual Interface connectors (DVI-D) with HDCP
1 DisplayPort 1.2 (DP)
1 Mini DisplayPort 1.2 (mDP)
1 High Definition Multimedia Interface (HDMI)
1 Video Graphics Array (VGA)
1 USB 3.0 upstream port
4 USB 3.0 downstream ports
1 DisplayPort out
1 Audio out
DC power connector for Dell Soundbar
Cena: 175€
https://i.dell.com/das/dih.ashx/673w/da ... torm-1.jpg
https://a1.amlimg.com/MWY3NTZkOTY4Zjc5M ... 5nfHx8.jpg
P: Dell UltraSharp 29 Ultrawide Monitor - U2913WM
Re: P: Dell UltraSharp 29 Ultrawide Monitor - U2913WM
Hajej...ful bi menjal doma. Namreč cena za velikost ekrana je fantastična. Sploh pa super ekran za tiste ki redno gledajo filme/serije.
...ampak 283mm višine z 1080 pixli mi je pa premalo ker mam ekran več kot meter stran od sebe pa redno delam z excelom in dokumenti pa rabim čimveč višine.
Zdaj mam Dell Ultrasharp IPS 24" 1200pixlov višine s 600nitsi in res žari pa ravno malo premalo pixlov ma po višini (ajde tut širini - ampak je najožji od ekranov 16/10)
Boli me da je višina tega tvojega ekrana nižja kot 22" ekran 16/10 ki ga mam kot sekundarnega.
Maš kej v 32"/34" ? pa da ma ~1500 pixlov po višini?
Nimam.
Kaj pa če daš tega pokonci. Pol imaš 2560 po višini? Gre lepo cel dokument v sliko.
