Odgovor Avtor: nebivedu » 16. Avgust 2015, 18:35
Pa če koga preveč moti da< MS pregleduje vse kar dcelate v windows 10, lahko tole kodo zalaufate:
(skopiraš v datoteko in jo shraniš kot ukaz.cmd, ter jo štartaš iz command prompta. Tole izklopi vse pošiljanje , keylogerje in podobne zadeve, ter odinštalira onedrive)
Koda: Izberi vse
@echo off
cls
echo This Script will do the following:
echo Disable Data Logging Services
echo Configure Windows Explorer
echo Uninstall Onedrive
echo Edit the Hosts file to block sending Telemetry Data to Microsoft
echo.
echo press any key to continue...
pause > NUL
echo Checking for Administrator elevation...
echo.
openfiles > NUL 2>&1
if %errorlevel%==0 (
	echo Elevation found! Proceeding...
) else (
	echo You are not running as Administrator...
	echo This batch cannot do it's job without elevation!
	echo.
	echo Right-click and select ^'Run as Administrator^' and try again...
	echo.
	echo Press any key to exit...
	pause > NUL
	exit
echo.
echo Disabling Data Logging Services
sc config diagtrack start=disabled
sc config dmwappushservice start=disabled
sc config RetailDemo start=disabled
reg add "HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Policies\DataCollection" /v AllowTelemetry /t REG_DWORD /d 0 /f > NUL 2>&1
reg add "HKEY_LOCAL_MACHINE\SOFTWARE\Wow6432Node\Microsoft\Windows\CurrentVersion\Policies\DataCollection" /v AllowTelemetry /t REG_DWORD /d 0 /f > NUL 2>&1
schtasks /change /TN "\Microsoft\Windows\Application Experience\Microsoft Compatibility Appraiser" /DISABLE
schtasks /change /TN "\Microsoft\Windows\Application Experience\ProgramDataUpdater" /DISABLE
schtasks /change /TN "\Microsoft\Windows\Customer Experience Improvement Program\Consolidator" /DISABLE
schtasks /change /TN "\Microsoft\Windows\Customer Experience Improvement Program\KernelCeipTask" /DISABLE
schtasks /change /TN "\Microsoft\Windows\Customer Experience Improvement Program\UsbCeip" /DISABLE
echo "" > C:\ProgramData\Microsoft\Diagnosis\ETLLogs\AutoLogger\AutoLogger-Diagtrack-Listener.etl
echo.
echo Removing all Folders from MyPC
REG DELETE "HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Explorer\MyComputer\NameSpace\{088e3905-0323-4b02-9826-5d99428e115f}" /f > NUL 2>&1
REG DELETE "HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Explorer\MyComputer\NameSpace\{1CF1260C-4DD0-4ebb-811F-33C572699FDE}" /f > NUL 2>&1
REG DELETE "HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Explorer\MyComputer\NameSpace\{24ad3ad4-a569-4530-98e1-ab02f9417aa8}" /f > NUL 2>&1
REG DELETE "HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Explorer\MyComputer\NameSpace\{374DE290-123F-4565-9164-39C4925E467B}" /f > NUL 2>&1
REG DELETE "HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Explorer\MyComputer\NameSpace\{3ADD1653-EB32-4cb0-BBD7-DFA0ABB5ACCA}" /f > NUL 2>&1
REG DELETE "HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Explorer\MyComputer\NameSpace\{3dfdf296-dbec-4fb4-81d1-6a3438bcf4de}" /f > NUL 2>&1
REG DELETE "HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Explorer\MyComputer\NameSpace\{A0953C92-50DC-43bf-BE83-3742FED03C9C}" /f > NUL 2>&1
REG DELETE "HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Explorer\MyComputer\NameSpace\{A8CDFF1C-4878-43be-B5FD-F8091C1C60D0}" /f > NUL 2>&1
REG DELETE "HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Explorer\MyComputer\NameSpace\{B4BFCC3A-DB2C-424C-B029-7FE99A87C641}" /f > NUL 2>&1
REG DELETE "HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Explorer\MyComputer\NameSpace\{d3162b92-9365-467a-956b-92703aca08af}" /f > NUL 2>&1
REG DELETE "HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Explorer\MyComputer\NameSpace\{f86fa3ab-70d2-4fc7-9c99-fcbf05467f3a}" /f > NUL 2>&1
echo.
echo Setup Windows Explorer View
REG ADD "HKEY_CURRENT_USER\SOFTWARE\Microsoft\Windows\CurrentVersion\Explorer\Advanced" /v LaunchTo /t REG_DWORD /d 1 /f > NUL 2>&1
REG ADD "HKEY_CURRENT_USER\SOFTWARE\Microsoft\Windows\CurrentVersion\Explorer\Advanced" /v HideFileExt /t REG_DWORD /d 0 /f > NUL 2>&1
REG ADD "HKEY_CURRENT_USER\SOFTWARE\Microsoft\Windows\CurrentVersion\Explorer\Advanced" /v Hidden /t REG_DWORD /d 1 /f > NUL 2>&1
REG DELETE "HKEY_CLASSES_ROOT\CABFolder\CLSID" /f > NUL 2>&1
REG DELETE "HKEY_CLASSES_ROOT\SystemFileAssociations\.cab\CLSID" /f > NUL 2>&1
REG DELETE "HKEY_CLASSES_ROOT\CompressedFolder\CLSID" /f > NUL 2>&1
REG DELETE "HKEY_CLASSES_ROOT\SystemFileAssociations\.zip\CLSID" /f > NUL 2>&1
echo.
echo Uninstalling OneDrive
set x86="%SYSTEMROOT%\System32\OneDriveSetup.exe"
set x64="%SYSTEMROOT%\SysWOW64\OneDriveSetup.exe"
taskkill /f /im OneDrive.exe > NUL 2>&1
ping 127.0.0.1 -n 5 > NUL 2>&1
if exist %x64% (
%x64% /uninstall
) else (
%x86% /uninstall
ping 127.0.0.1 -n 8 > NUL 2>&1
rd "%USERPROFILE%\OneDrive" /Q /S > NUL 2>&1
rd "C:\OneDriveTemp" /Q /S > NUL 2>&1
rd "%LOCALAPPDATA%\Microsoft\OneDrive" /Q /S > NUL 2>&1
rd "%PROGRAMDATA%\Microsoft OneDrive" /Q /S > NUL 2>&1
echo.
echo Removeing OneDrive from the Explorer Side Panel.
REG DELETE "HKEY_CLASSES_ROOT\CLSID\{018D5C66-4533-4307-9B53-224DE2ED1FE6}" /f > NUL 2>&1
REG DELETE "HKEY_CLASSES_ROOT\Wow6432Node\CLSID\{018D5C66-4533-4307-9B53-224DE2ED1FE6}" /f > NUL 2>&1
echo.
echo Editing Hosts File
SET NEWLINE=^& echo.
FIND /C /I "telemetry.microsoft.com" %WINDIR%\system32\drivers\etc\hosts > NUL 2>&1
IF %ERRORLEVEL% NEQ 0 ECHO %NEWLINE%^0.0.0.0 telemetry.microsoft.com>>%WINDIR%\System32\drivers\etc\hosts
FIND /C /I "vortex.data.microsoft.com" %WINDIR%\system32\drivers\etc\hosts > NUL 2>&1
IF %ERRORLEVEL% NEQ 0 ECHO %NEWLINE%^0.0.0.0 vortex.data.microsoft.com>>%WINDIR%\System32\drivers\etc\hosts
FIND /C /I "vortex-win.data.microsoft.com" %WINDIR%\system32\drivers\etc\hosts > NUL 2>&1
IF %ERRORLEVEL% NEQ 0 ECHO %NEWLINE%^0.0.0.0 vortex-win.data.microsoft.com>>%WINDIR%\System32\drivers\etc\hosts
FIND /C /I "telecommand.telemetry.microsoft.com" %WINDIR%\system32\drivers\etc\hosts > NUL 2>&1
IF %ERRORLEVEL% NEQ 0 ECHO %NEWLINE%^0.0.0.0 telecommand.telemetry.microsoft.com>>%WINDIR%\System32\drivers\etc\hosts
FIND /C /I "telecommand.telemetry.microsoft.com.nsatc.net" %WINDIR%\system32\drivers\etc\hosts > NUL 2>&1
IF %ERRORLEVEL% NEQ 0 ECHO %NEWLINE%^0.0.0.0 telecommand.telemetry.microsoft.com.nsatc.net>>%WINDIR%\System32\drivers\etc\hosts
FIND /C /I "oca.telemetry.microsoft.com" %WINDIR%\system32\drivers\etc\hosts > NUL 2>&1
IF %ERRORLEVEL% NEQ 0 ECHO %NEWLINE%^0.0.0.0 oca.telemetry.microsoft.com>>%WINDIR%\System32\drivers\etc\hosts
FIND /C /I "oca.telemetry.microsoft.com.nsatc.net" %WINDIR%\system32\drivers\etc\hosts > NUL 2>&1
IF %ERRORLEVEL% NEQ 0 ECHO %NEWLINE%^0.0.0.0 oca.telemetry.microsoft.com.nsatc.net>>%WINDIR%\System32\drivers\etc\hosts
FIND /C /I "sqm.telemetry.microsoft.com" %WINDIR%\system32\drivers\etc\hosts > NUL 2>&1
IF %ERRORLEVEL% NEQ 0 ECHO %NEWLINE%^0.0.0.0 sqm.telemetry.microsoft.com>>%WINDIR%\System32\drivers\etc\hosts
FIND /C /I "sqm.telemetry.microsoft.com.nsatc.net" %WINDIR%\system32\drivers\etc\hosts > NUL 2>&1
IF %ERRORLEVEL% NEQ 0 ECHO %NEWLINE%^0.0.0.0 sqm.telemetry.microsoft.com.nsatc.net>>%WINDIR%\System32\drivers\etc\hosts
FIND /C /I "watson.telemetry.microsoft.com" %WINDIR%\system32\drivers\etc\hosts > NUL 2>&1
IF %ERRORLEVEL% NEQ 0 ECHO %NEWLINE%^0.0.0.0 watson.telemetry.microsoft.com>>%WINDIR%\System32\drivers\etc\hosts
FIND /C /I "watson.telemetry.microsoft.com.nsatc.net" %WINDIR%\system32\drivers\etc\hosts > NUL 2>&1
IF %ERRORLEVEL% NEQ 0 ECHO %NEWLINE%^0.0.0.0 watson.telemetry.microsoft.com.nsatc.net>>%WINDIR%\System32\drivers\etc\hosts
FIND /C /I "redir.metaservices.microsoft.com" %WINDIR%\system32\drivers\etc\hosts > NUL 2>&1
IF %ERRORLEVEL% NEQ 0 ECHO %NEWLINE%^0.0.0.0 redir.metaservices.microsoft.com>>%WINDIR%\System32\drivers\etc\hosts
FIND /C /I "choice.microsoft.com" %WINDIR%\system32\drivers\etc\hosts > NUL 2>&1
IF %ERRORLEVEL% NEQ 0 ECHO %NEWLINE%^0.0.0.0 choice.microsoft.com>>%WINDIR%\System32\drivers\etc\hosts
FIND /C /I "choice.microsoft.com.nsatc.net" %WINDIR%\system32\drivers\etc\hosts > NUL 2>&1
IF %ERRORLEVEL% NEQ 0 ECHO %NEWLINE%^0.0.0.0 choice.microsoft.com.nsatc.net>>%WINDIR%\System32\drivers\etc\hosts
FIND /C /I "df.telemetry.microsoft.com" %WINDIR%\system32\drivers\etc\hosts > NUL 2>&1
IF %ERRORLEVEL% NEQ 0 ECHO %NEWLINE%^0.0.0.0 df.telemetry.microsoft.com>>%WINDIR%\System32\drivers\etc\hosts
FIND /C /I "wes.df.telemetry.microsoft.com" %WINDIR%\system32\drivers\etc\hosts > NUL 2>&1
IF %ERRORLEVEL% NEQ 0 ECHO %NEWLINE%^0.0.0.0 wes.df.telemetry.microsoft.com>>%WINDIR%\System32\drivers\etc\hosts
FIND /C /I "reports.wes.df.telemetry.microsoft.com" %WINDIR%\system32\drivers\etc\hosts > NUL 2>&1
IF %ERRORLEVEL% NEQ 0 ECHO %NEWLINE%^0.0.0.0 reports.wes.df.telemetry.microsoft.com>>%WINDIR%\System32\drivers\etc\hosts
FIND /C /I "services.wes.df.telemetry.microsoft.com" %WINDIR%\system32\drivers\etc\hosts > NUL 2>&1
IF %ERRORLEVEL% NEQ 0 ECHO %NEWLINE%^0.0.0.0 services.wes.df.telemetry.microsoft.com>>%WINDIR%\System32\drivers\etc\hosts
FIND /C /I "sqm.df.telemetry.microsoft.com" %WINDIR%\system32\drivers\etc\hosts > NUL 2>&1
IF %ERRORLEVEL% NEQ 0 ECHO %NEWLINE%^0.0.0.0 sqm.df.telemetry.microsoft.com>>%WINDIR%\System32\drivers\etc\hosts
FIND /C /I "watson.ppe.telemetry.microsoft.com" %WINDIR%\system32\drivers\etc\hosts > NUL 2>&1
IF %ERRORLEVEL% NEQ 0 ECHO %NEWLINE%^0.0.0.0 watson.ppe.telemetry.microsoft.com>>%WINDIR%\System32\drivers\etc\hosts
FIND /C /I "telemetry.appex.bing.net" %WINDIR%\system32\drivers\etc\hosts > NUL 2>&1
IF %ERRORLEVEL% NEQ 0 ECHO %NEWLINE%^0.0.0.0 telemetry.appex.bing.net>>%WINDIR%\System32\drivers\etc\hosts
FIND /C /I "telemetry.urs.microsoft.com" %WINDIR%\system32\drivers\etc\hosts > NUL 2>&1
IF %ERRORLEVEL% NEQ 0 ECHO %NEWLINE%^0.0.0.0 telemetry.urs.microsoft.com>>%WINDIR%\System32\drivers\etc\hosts
FIND /C /I "telemetry.appex.bing.net:443" %WINDIR%\system32\drivers\etc\hosts > NUL 2>&1
IF %ERRORLEVEL% NEQ 0 ECHO %NEWLINE%^0.0.0.0 telemetry.appex.bing.net:443>>%WINDIR%\System32\drivers\etc\hosts
FIND /C /I "settings-sandbox.data.microsoft.com" %WINDIR%\system32\drivers\etc\hosts > NUL 2>&1
IF %ERRORLEVEL% NEQ 0 ECHO %NEWLINE%^0.0.0.0 settings-sandbox.data.microsoft.com>>%WINDIR%\System32\drivers\etc\hosts
FIND /C /I "vortex-sandbox.data.microsoft.com" %WINDIR%\system32\drivers\etc\hosts > NUL 2>&1
IF %ERRORLEVEL% NEQ 0 ECHO %NEWLINE%^0.0.0.0 vortex-sandbox.data.microsoft.com>>%WINDIR%\System32\drivers\etc\hosts
FIND /C /I "watson.microsoft.com" %WINDIR%\system32\drivers\etc\hosts > NUL 2>&1
IF %ERRORLEVEL% NEQ 0 ECHO %NEWLINE%^0.0.0.0 watson.microsoft.com>>%WINDIR%\System32\drivers\etc\hosts
FIND /C /I "survey.watson.microsoft.com" %WINDIR%\system32\drivers\etc\hosts > NUL 2>&1
IF %ERRORLEVEL% NEQ 0 ECHO %NEWLINE%^0.0.0.0 survey.watson.microsoft.com>>%WINDIR%\System32\drivers\etc\hosts
FIND /C /I "watson.live.com" %WINDIR%\system32\drivers\etc\hosts > NUL 2>&1
IF %ERRORLEVEL% NEQ 0 ECHO %NEWLINE%^0.0.0.0 watson.live.com>>%WINDIR%\System32\drivers\etc\hosts
FIND /C /I "statsfe2.ws.microsoft.com" %WINDIR%\system32\drivers\etc\hosts > NUL 2>&1
IF %ERRORLEVEL% NEQ 0 ECHO %NEWLINE%^0.0.0.0 statsfe2.ws.microsoft.com>>%WINDIR%\System32\drivers\etc\hosts
FIND /C /I "corpext.msitadfs.glbdns2.microsoft.com" %WINDIR%\system32\drivers\etc\hosts > NUL 2>&1
IF %ERRORLEVEL% NEQ 0 ECHO %NEWLINE%^0.0.0.0 corpext.msitadfs.glbdns2.microsoft.com>>%WINDIR%\System32\drivers\etc\hosts
FIND /C /I "compatexchange.cloudapp.net" %WINDIR%\system32\drivers\etc\hosts > NUL 2>&1
IF %ERRORLEVEL% NEQ 0 ECHO %NEWLINE%^0.0.0.0 compatexchange.cloudapp.net>>%WINDIR%\System32\drivers\etc\hosts
FIND /C /I "cs1.wpc.v0cdn.net" %WINDIR%\system32\drivers\etc\hosts > NUL 2>&1
IF %ERRORLEVEL% NEQ 0 ECHO %NEWLINE%^0.0.0.0 cs1.wpc.v0cdn.net>>%WINDIR%\System32\drivers\etc\hosts
FIND /C /I "a-0001.a-msedge.net" %WINDIR%\system32\drivers\etc\hosts > NUL 2>&1
IF %ERRORLEVEL% NEQ 0 ECHO %NEWLINE%^0.0.0.0 a-0001.a-msedge.net>>%WINDIR%\System32\drivers\etc\hosts
FIND /C /I "fe2.update.microsoft.com.akadns.net" %WINDIR%\system32\drivers\etc\hosts > NUL 2>&1
IF %ERRORLEVEL% NEQ 0 ECHO %NEWLINE%^0.0.0.0 fe2.update.microsoft.com.akadns.net>>%WINDIR%\System32\drivers\etc\hosts
FIND /C /I "statsfe2.update.microsoft.com.akadns.net" %WINDIR%\system32\drivers\etc\hosts > NUL 2>&1
IF %ERRORLEVEL% NEQ 0 ECHO %NEWLINE%^0.0.0.0 statsfe2.update.microsoft.com.akadns.net>>%WINDIR%\System32\drivers\etc\hosts
FIND /C /I "sls.update.microsoft.com.akadns.net" %WINDIR%\system32\drivers\etc\hosts > NUL 2>&1
IF %ERRORLEVEL% NEQ 0 ECHO %NEWLINE%^0.0.0.0 sls.update.microsoft.com.akadns.net>>%WINDIR%\System32\drivers\etc\hosts
FIND /C /I "diagnostics.support.microsoft.com" %WINDIR%\system32\drivers\etc\hosts > NUL 2>&1
IF %ERRORLEVEL% NEQ 0 ECHO %NEWLINE%^0.0.0.0 diagnostics.support.microsoft.com>>%WINDIR%\System32\drivers\etc\hosts
FIND /C /I "corp.sts.microsoft.com" %WINDIR%\system32\drivers\etc\hosts > NUL 2>&1
IF %ERRORLEVEL% NEQ 0 ECHO %NEWLINE%^0.0.0.0 corp.sts.microsoft.com>>%WINDIR%\System32\drivers\etc\hosts
FIND /C /I "statsfe1.ws.microsoft.com" %WINDIR%\system32\drivers\etc\hosts > NUL 2>&1
IF %ERRORLEVEL% NEQ 0 ECHO %NEWLINE%^0.0.0.0 statsfe1.ws.microsoft.com>>%WINDIR%\System32\drivers\etc\hosts
FIND /C /I "pre.footprintpredict.com" %WINDIR%\system32\drivers\etc\hosts > NUL 2>&1
IF %ERRORLEVEL% NEQ 0 ECHO %NEWLINE%^0.0.0.0 pre.footprintpredict.com>>%WINDIR%\System32\drivers\etc\hosts
FIND /C /I "i1.services.social.microsoft.com" %WINDIR%\system32\drivers\etc\hosts > NUL 2>&1
IF %ERRORLEVEL% NEQ 0 ECHO %NEWLINE%^0.0.0.0 i1.services.social.microsoft.com>>%WINDIR%\System32\drivers\etc\hosts
FIND /C /I "i1.services.social.microsoft.com.nsatc.net" %WINDIR%\system32\drivers\etc\hosts > NUL 2>&1
IF %ERRORLEVEL% NEQ 0 ECHO %NEWLINE%^0.0.0.0 i1.services.social.microsoft.com.nsatc.net>>%WINDIR%\System32\drivers\etc\hosts
FIND /C /I "feedback.windows.com" %WINDIR%\system32\drivers\etc\hosts > NUL 2>&1
IF %ERRORLEVEL% NEQ 0 ECHO %NEWLINE%^0.0.0.0 feedback.windows.com>>%WINDIR%\System32\drivers\etc\hosts
FIND /C /I "feedback.microsoft-hohm.com" %WINDIR%\system32\drivers\etc\hosts > NUL 2>&1
IF %ERRORLEVEL% NEQ 0 ECHO %NEWLINE%^0.0.0.0 feedback.microsoft-hohm.com>>%WINDIR%\System32\drivers\etc\hosts
FIND /C /I "feedback.search.microsoft.com" %WINDIR%\system32\drivers\etc\hosts > NUL 2>&1
IF %ERRORLEVEL% NEQ 0 ECHO %NEWLINE%^0.0.0.0 feedback.search.microsoft.com>>%WINDIR%\System32\drivers\etc\hosts
echo.
echo.
echo Please make sure you do the following as well:
echo Head to Settings > Privacy, and disable everything, unless there are some things you really need.
echo While within the Privacy page, go to Feedback, select Never in the first box, and Basic in the second box
pause
pause
Odgovor Avtor: danci1973 » 16. Avgust 2015, 22:36
nebivedu napisal/-a: Kaj pa imaš za eno?
V službi imamo en kupček HP Pavilion-ov in večina nima WOL... Sem ga hotel uporabit, da bi se mašine avtomatsko prižgale ponoči, naredile backup in se potem spet ugasnile.
nebivedu napisal/-a: Preko routerja ti pošiljaš vse pakete tako ven kot notri. MP ni nič posebnega in v veliki večini jih routerji niti ne zaznajo kot "nevarnost". Poleg tega ti na router nekdo pride in pošilja iz njega MP-je. Sej imajo sedaj v večini routerji linux gor in se jih da lepo kontrolirat.
:lol:
Odgovor Avtor: nebivedu » 16. Avgust 2015, 22:55
danci1973 napisal/-a:
čudno, pri nas so imeli že pavillioni z P4 procesorji WOL. So jih ob 18h vse ugasnili na daljavo in zjutraj ob 6h prižgali (skripta + wol). Smo na mesec za več kot 100.000 evrov prišparal samo na elektriki.
Imaš pa še eno rešitev, vsi imajo alarm v biosu in prižiganje ob določeni uri. Nastaviš, da se vsi prižgejo in narediš backup, potem pa ugasneš. Samo to moraš potem na vsakem fizično nastavit, ker moraš v bios.
Odgovor Avtor: danci1973 » 16. Avgust 2015, 23:49
nebivedu napisal/-a: čudno, pri nas so imeli že pavillioni z P4 procesorji WOL. So jih ob 18h vse ugasnili na daljavo in zjutraj ob 6h prižgali (skripta + wol). Smo na mesec za več kot 100.000 evrov prišparal samo na elektriki.
:shock: Po današnjih cenah je to cca. 1428 MWh...
Odgovor Avtor: nebivedu » 17. Avgust 2015, 00:06
Ne moreš gledat samo po kilowatih. Take firme plačujejo pavšal, ki pa se določi verjetno glede na špice. In računalniški centri, ki obdelujejo transakcije, verjetno imajo hude špice na ključne dneve (8., 15., 18., 28.), ker je takrat nekajkrat povečan obseg. Moraš pa računat, da je to nekje 600 do 700 serverjev, vsaj 5000 računalnikov in nekaj mainframeov, ter gora diskov (vse mora biti po 3x kopirano). Vsak mainframe pa na uro požre nekje malo čez 30kW (18kw osnovna enota in 14kw hot-ready backup enota)
Odgovor Avtor: Sajmon » 17. Avgust 2015, 06:49
Tista s privarčevano elektriko je tudi meni mal bosa. Potemtakem bi se serversobe smatrale za talilnice. Res me zanima, koko izgleda električna inštalacija, pa jih nisem videl malo.
Odgovor Avtor: nebivedu » 17. Avgust 2015, 07:13
Hmm, to ni samo server soba. To je prostor v velikosti nogometnega igrišča povhen mainframeov in serverjev, ter kr nekaj poslovalnic.
Pa vključeno je v to šparanje še sprememba iz fizičnih na virtualne serverje. Nekih 300 je šlo v virtualke. Če računaš na en server 1kw napajalnik + redundanco + cluster dveh ali večih, ker je vse vsaj podvojeno in to vse dela, ker mora preklopit takoj le kaj crkne.
Odgovor Avtor: danci1973 » 17. Avgust 2015, 08:31
nebivedu napisal/-a:Hmm, to ni samo server soba. To je prostor v velikosti nogometnega igrišča povhen mainframeov in serverjev, ter kr nekaj poslovalnic.
Pa dobro, mainframe-ov menda niste ugašali in zbujali z WOL.. :D
Odgovor Avtor: Sajmon » 17. Avgust 2015, 09:24
Nebivedu, a ti po novem pr guglu delaš? :-) Pri nas mal dvomim, da bi imel kaj takega.
Odgovor Avtor: nebivedu » 17. Avgust 2015, 13:36
Sajmon napisal/-a:Nebivedu, a ti po novem pr guglu delaš? :-) Pri nas mal dvomim, da bi imel kaj takega.
Dvomiš? No ni ti treba. Naš računalniški center je ogromna stavba in na sredini je "server room" v velikosti nogometnega igrišča (na male gole, ampak vseeno ogromno).
Odgovor Avtor: nebivedu » 17. Avgust 2015, 13:47
Seveda da ne. Očitno se ne razumemo. Da še enkrat razložim. IT z ogromno računalniki ima enormno porabo elektrike. Plačuje se pavšal, glede na špice v porabi. Torej 15-tega, ko so plače ali 18-tega ko so trajniki imaš enormno porabo, ker vse deluje skoraj na 100% in elektro ti glede na to špico potem pavšal postavi. Tukaj moraš še računat na klimo za tak prostor (ali pa klime, ker jih je več), vodne črpalke za hlajenje in podobno.
Sedaj če ti 1000 serverjev laufa non stop z 2x po 1kw napajalniki, je to že orenk poraba. Če jih 300 postaviš v virtualke, je kar naenkrat manjša poraba, manj segrevanja in tako ti tudi klime lahko manj delajo.
In s tem ogromno prišparaš. Bo to sedaj bolj jasno.
Sajmon, nekaj podobnega temu, samo da je manj mainframeov in več server rackov, terr diskovnih polj.
http://www.bloomberg.com/image/i1aupOZK_wB8.jpg
Odgovor Avtor: Sajmon » 18. Avgust 2015, 00:21
hehe, Ljubljana sploh ne bi rabila toplarne za ogrevanje. :-)
A bi mi kdo lahko preveril en VIN, če kaj več pove, recimo na carfaxu?
Prispevki: 5386
Odgovor Avtor: klemz » 18. Avgust 2015, 21:55
VIN za kater avto?
Odgovor Avtor: Sajmon » 19. Avgust 2015, 06:43
Ah, en forester.
