OUTBACK 2.5 `06
Re: OUTBACK 2.5 `06
Odgovor Avtor: Sajmon » 14. Marec 2018, 07:30
Another major recall issued on October 20 expanded the affected vehicles across several brands. For its part, Toyota said it would begin to replace defective passenger-side inflators starting October 25; if parts are unavailable, however, it has advised its dealers to disable the airbags and affix “Do Not Sit Here” messages to the dashboard.
:ast :smly
Re: OUTBACK 2.5 `06
Odgovor Avtor: zabrnek » 03. September 2018, 14:44
A mi lahko kdo po kmečko razlozi kaj je tocno narobe, če mi javi napako P0137?
Tudi ce jo pobrisem se v kratkem pojavi nazaj, torej je ta zadeva res crknila.
Re: OUTBACK 2.5 `06
Odgovor Avtor: klemz » 03. September 2018, 15:11
Tadruga lambda ti ga serje, loh je losana, kabl, konektor, crknla cist.
Re: OUTBACK 2.5 `06
Odgovor Avtor: zabrnek » 03. September 2018, 16:02
Ok. Hvala.
A ma kdo to tadrugo lambdo kje na ponk? Karli mogoče?
Prispevki: 8741
Re: OUTBACK 2.5 `06
Odgovor Avtor: nebivedu » 03. September 2018, 16:37
Imam eno
Re: OUTBACK 2.5 `06
Odgovor Avtor: zabrnek » 03. September 2018, 16:47
Delujočo?
Koliko v€vrc hočeš?
Prispevki: 4465
Re: OUTBACK 2.5 `06
Odgovor Avtor: danci1973 » 03. September 2018, 17:00
Lahko, da je tudi kaj s kabli ali konektorjem.
Prispevki: 5059
Re: OUTBACK 2.5 `06
Odgovor Avtor: karel » 03. September 2018, 19:09
Drugo lambdo jaz podložim z distančnikom in računalnik ne dela več scene...
Problem pa ni v lambdi temveč v zanič katalizatorju, ki ne opravlja več svoje funkcije.
Re: OUTBACK 2.5 `06
Odgovor Avtor: zabrnek » 03. September 2018, 19:59
Ok. Mi boš pokazal kaksen distancnik daš vmes ko pridem naokoli.
Re: OUTBACK 2.5 `06
Odgovor Avtor: klemz » 04. September 2018, 05:00
Vrjetno podstav s podloskami.
Re: OUTBACK 2.5 `06
Odgovor Avtor: zabrnek » 04. September 2018, 07:49
Ja najbrz. Samo koliko podlozk oz. Visino distancnika pa raje vprasam Karlija, kot da sam probavam.
Prispevki: 4465
Re: OUTBACK 2.5 `06
Odgovor Avtor: danci1973 » 04. September 2018, 10:38
Baje da za Subaruje, novejše od 2005, to ni dobro.
https://forums.nasioc.com/forums/showth ... ?t=2234058
Forum je ameriški, tako da koliko to drži tudi za evropske izvedbe, je vprašanje.
Perezvon
Prispevki: 131
Re: OUTBACK 2.5 `06
Odgovor Avtor: Perezvon » 10. Januar 2019, 09:28
Živjo, Da ne načenjam nove teme. Meni je tudi popolnoma crknil en injektor BRC naprave na bi-fuel 2.5 outbacku 09'
Imam 200k km, se splača vse 4 menjati? Koliko je to strošek?
Hvala in LP
Prispevki: 5489
Re: OUTBACK 2.5 `06
Odgovor Avtor: BackW00d » 10. Januar 2019, 10:16
Če si vsaj malo spreten z orodjem, pa da te ni strah da bo kabum. In če imaš smisel in izkušnje z napeljevanjem lajtung...
Potem naročiš* iz tujine takale HANA injektorje (HANA so na internetu po mojih izkušnjah znani kot zelo dobri injektorji)
https://www.lpgshop.co.uk/hana-h2001-a- ... stributor/
https://www.lpgshop.co.uk/hana-h2001-a- ... with-rail/
Ali pa vzameš kake injektorje z normalno ceno:
https://www.lpgshop.co.uk/single-injectors/
*Pozoren moraš bit, da je šoba ista (ta uravnava količino goriva ki lahko gre skozi injektor v nekem časovnem intervalu) pa seveda je pametno vzet take, da konektor paše.
*Pa seveda Voltažo mora met isto.
Sam ne vem katere injektorje uporablja BRC. Verjetno najbolj zmagaš, da dobiš prav iste (proizvajalec/model).
Ali pa greš do kakega plinašomonterja, pa ti bo to verjetno uredil za okolico 2× cene materiala. Torej material+delo.
Odvisno kakšne sorte monter je...
Prispevki: 4465
Re: OUTBACK 2.5 `06
Odgovor Avtor: danci1973 » 10. Januar 2019, 10:29
BRC ima svoje injektorje:
https://slideplayer.com/slide/1710037/7 ... C+IN03.jpg
Različne barve pomenijo različen pretok plina, pazit pa moraš še na to, ali imaš za cev priklop z navojem ali brez...
Najnižja cena na eBay-u je 48,90€ na kos.
Menjava vseh štirih je smotrna, ker so lahko med starimi in novimi serijami injektorjev razlike v pretoku plina - bo pa po menjavi vseh najbrž potrebna prilagoditev nastavitev...
Ne vem, če lahko z BRC-jevim računalnikom kar tako enostavno uporabljaš druge injektorje.
Imam pa jaz še par starih, a delujočih oranžnih injektorjev z navojem.
