Ickoficko ima svoj foto-kamperaški blog.
Re: Ickoficko ima svoj foto-kamperaški blog.
mene pa zanima, ko si bil na Sardiji s kamperjem, ali ste spali v
kampih ali kar tako
lp kiki
kampih ali kar tako
lp kiki
Kar tako po plažah, vendar je v juliju in še posebej v avgustu malo gužve. Mi smo bili vedno septembra ko makaroni odidejo.
Odlične fotografije in pot. Vsa čast!
Sem imel šele sedaj čas prebrati, lepo opisano doživetje, tnx.
Ura se je prestavila, večeri so dolgi...
http://ickoficko.wordpress.com/2012/11/" onclick="window.open(this.href);return false; ... v-friuliu/
Cool.... :.sup oh in sploh.
Tisti izvir me pa strašno zanima,ker na sliki je res prekrasnih barv
Ali veš mogoče kako se imenuje
http://www.magicoveneto.it/friuli/Liven ... rgazzo.htm" onclick="window.open(this.href);return false;
če ne pa še malo wikipedijo uporabi.
Na skoraj vseh slikah se vidi v vodi križ ali nekaj podobnega,si ga ti tudi videl?
Jap
Le tega so vstavili potapljači (kao varuha?) ki med drugim na vsak božični večer z neoprensko in svetilkami uprizorijo pravi podvodni light shov.
vir
Gorgazzo
"Take the emerald colour, the turquoise and the beryl ones, cast them into a bath of lapis-lazuli, so that everything meets and, at the same time, each of them keeps its own originality and you will get that part of liquid sky named Gorgazzo."
"Bus del Gorgàz" - Gorgazzo's spring.
These words were used by geographer Giovanni Marinelli in 1877 about the springs of Gorgazzo torrent, which flow out the slopes of the mountain from a dramatic underwater cave generated by water erosion. The torrent, which the Hamlet is named after, crosses pleasantly through the historical centre and flows into river Livenza. The spring is one of the deepest siphon in Europe and it has not been wholly explored yet. The surface pond had originated from the collapse of the vault under water's thrust. The water origin is not well known. Nevertheless, several studies have been carried out on the floods of this spring which undergo seasonal variations; this research strengthens the hypothesis of an origin from high places. There is also another hypothesis of a large feeding basin extending for approx 90 km2. In the past, nine scuba divers have died attempting to reach the bottom of the cave and as a result swimming is prohibited. Future research could give an answer to the questions which still wrap this marvel of Nature in mystery.
On Christmas Eve, during the Mass traditionally celebrated at the spring, a couple of divers plunge in the source to crown the Christ of the Abyss, a little statue hanging against the caves's surface 10 meters underwater, which can hardly be seen on shiny days because the water level has never been low enough to expose it, not even during the driest summer ever registered. The divers dive into the water bringing flashlights and the magic atmosphere of Christmas makes the ceremony very impressive.
vir
Gorgazzo
Madona, hude fotke
Lepo. Všeč mi je, ko vidim ljudi, ki si na potovanju res vzamejo čas za fotografijo in čakajo dobro svetlobo.
Keep it up!
Keep it up!
Zima za "zapečkarje"
http://ickoficko.wordpress.com/2012/12/ ... bregampak/" onclick="window.open(this.href);return false;
Odlično!
Se moraš res zadržati in ne potacaš svežega snega preden poslikaš to čudovito zasneženo pokrajino..
Impreza Sti 08
Kaj šele razriješ s subarujem
