Nakup XV
Re: Nakup XV
H6 je šel od doma
Re: Nakup XV
Se popravljam, hill assist ni za strmo spuščanje, je samo novejši tip hill holderja.
Re: Nakup XV
Tanovi naj bi imeli eno zadevo za spuščanje po klancu. Moj še nima (al pa ima, pa še nisem našel).
- Prispevki: 4475
Re: Nakup XV
To naj bi bila ena od funkcij X-mode-a...
Ali to velja za vse X-mode generacije ali samo za novejše, pa žal ne vem.Pressing the X-Mode switch activates 5 different forms of control to limit slipping tires:
1. Engine Throttle
In normal driving, when the driver steps on the accelerator pedal, the engine throttle opens up, however X-Mode is designed so that the throttle doesn't open too quickly. If the driver presses the accelerator further, the engine then delivers torque faster. X-Mode employs special settings that deliver torque gradually at first, but then makes it come on stronger.
2. Transmission
X-Mode keeps transmission in a lower gear so that engine power can be delivered stronger. This shifting pattern, while X-Mode is ON, lets the driver make the most of the power that is available.
3. All Wheel Drive
AWD control is improved by raising the front/rear coupling force when X-Mode is ON, which helps the driver drive power more evenly between the four wheels. This maximizes the traction of the tires.
4. Vehicle Dynamics Control System
The VDC system, when X-Mode is ON, includes a specially-tuned "Enhanced LSD Control". For example, if the left and right wheels are behaving differently, the system applies brakes only to wheels that are slipping. Compared to ordinary operation, the brakes are applied a lot earlier when X-Mode is ON, resulting in LSD control activating much faster.
5. Hill Descent Control
At low speeds (under 12 mph) Hill Descent Control helps maintain vehicle starting speed for safer maneuvering--the car itself manages the throttle and breaking allowing the driver to fully concentrate on steering.
Re: Nakup XV
Ta v oglasu ni naprodaj, ampak je le primer po naročilu. Sem jih pa že kontaktirala, pa tudi Autobroker, ki uvažajo iz tujine.
Na mobile.de imam že par ogledanih. V ponudbi sem opazila tudi ameriško verzijo Crosstrek, ampak ne vem, kako je glede izdelave, ker so narejeni v Zda, evropski pa na Japonskem.
Nakup novega ne pride v poštev, ker je cena 23k € za 1,6 z osnovno opremo. Samo zaradi eyesighta ni vredno, imam raje rabljenega 2.0 pa xenonke za manj denarja.
Re: Nakup XV
Danes sem sprobal 2.0 motor v XV-ju, 36 konjev več ne odtehta. Se mi zdi čisto neprožna mašina. Mogoče v višjih obratih, ampak za v kolone je pa patetična. Speljuje kot da si na 600 obratih. K da se noče premaknit nikamor. Se mi zdi, da je 1.6 bolj odzivna mašina, lepše se pelje, lepše speljuje s križišč, manj je tresenja mašine pri pospeševanju, lažje in hitreje pride do željene hitrosti (do 120km/h, več nisem sprobaval). Končno ima 2.0 res višjo, ampak tisto me ne zanima. Zanimivo pa da po 100km vožnje nisem uspel spravit porabe pod to, ki jo imam na mojem XV-ju (7.6l/100km).
Pa kar je meni najbolj moteče pri "testnem" 2.0: Simulirat hoče prestavljanje in ima 6 prednastavljenih prestav. Zakaj bi to rabil pri CVT menjalniku? Če že imaš skuter menjalnik, naj vsaj od 0 do končne vleče brez "prestavljanja".
Re: Nakup XV
Simulacija prestavljanja, da sam šaltaš na volanu (paddle shifters)? Ziher prav pride v kritični situaciji, ko rabiš nižjo prestavo od avtomatično izbrane.
Po testih na YT je verzija z ročnim menjalnikom bolj živahna, ker so avtomatiki naštelani bolj na šparanje z gorivom. Končna brzina tudi meni ni toliko pomembna, mi pa je odzivnost, sploh v mestu ali pri prehitevanju.
Sem pa v mojem finančnem rangu gledala tudi enega Legacyja 2,5i v kombinaciji bencin s cng plinom. Sicer sta trenutno samo 2 pumpi v Lj.
Ima kdo na forumu izkušnje z vzdrževanjem teh motorjev in cng?
Re: Nakup XV
Sem na forumu brala problem s servisiranjem plinske napeljave. Klinc vse skupaj, ni čudno, da je ta Legacy že toliko časa v oglasu. Najbolje, da vzamem bencinarja z ročnim menjalnikom in nič dodatnih elektronskih gizmotov, klasika bo še najmanj zajebavanja.
@Nebivedu: kako, da je imel 1,6 boljše pospeške kot 2.0, če ima v specifikacijah en 13 drugi 10?
Re: Nakup XV
Itak, da ima 1.6 boljše pospeške od 2.0. Še dobro, da Subaru ne dela več 3.0 H6, to bi bila šele nepremičnina.
Sorry, moral sem.
Sorry, moral sem.
Re: Nakup XV
Mam doma imprrezo 1.5. Ajde, to res nikamor ne gre, ampak 2.0 XV povezavi s CVT menjalnikom je čisti poraz (al pa je sam ta avto, ki sem ga fural tak poraz, sicer je imel šele 250k kilometrov, ampak...).
Spelješ, pa sam kao šalta v višjo - sumulacija, ki mu oduzame gas, kao prešalta in doda gas, čeprav pedal za gas držiš tako kot takrat ko si speljal. Kot da bi speljeval en star ata na križišču s svojim golfom 2 dizel, k hoče še mal na gorivu prišparat, pa ne da dost gasa. Pa zdi se mi kot da se mašina orenk matra da avto prestavlja.
Naj bi 2.0 imel 3 sekunde boljši čas od 0 do 100, pa po občutku tist avto ni šel tako dobro kot naj bi šel.
Re: Nakup XV
Mogoče pa so prestavna razmerja pri cvt bolj prilagojena 1.6 motorju.
Sem na Mobile.de opazila, da imajo 1,6 z ročnim menjalnikom še eno ročko, a je to reduktor?
Re: Nakup XV
a ni fora cvt ravno v tem da ima "neskončno" prestavnih razmerij
Re: Nakup XV
Govorim monade, res je. Možno, da je pa Nebivedu vozil enega zmatranega 2.0.
http://www.subarucomplaints.com/cvt/
