Vseen se grem pelat... Zima 2021/22
Re: Vseen se grem pelat... Zima 2021/22
Lahko pa da so cifre samo, kako bi se izrazu, oznake. Recimo kot pri urah. 50m globine ---> zdrži tuširanje. Al pa da dejansko odtisnena cifra 1.5 T, pomen nekje razred osebnih vozil, 3T kombije, etc.... Američani bi sigurn tko mel.
Pejmo z avto!
Jp. Vertikalni vitli imajo večji varnostni koeficient
- Prispevki: 4465
https://www.safetyliftingear.com/news/p ... difference
Winch vs Hoist: What's the Difference?
Some people use the words 'winch' and 'hoist' interchangeably, but there is a difference between the two, and it's important to understand that difference before you decide which product to use for a certain job.
The basic difference is as follows: Hoists lift things. Winches pull things.
Winches are designed to pull loads horizontally across a relatively level surface, whereas hoists can be used to lift loads vertically and suspend them in mid-air.
Can a winch be used as a hoist?
Generally speaking, no. It is not safe to use a standard winch to lift loads up off the ground, as it wasn't designed for this purpose and there is a risk that the load will be dropped.
One of the key differences between winches and hoists lies in their braking systems.
However, there is some overlap: certain winching products are designed to double up as hoists. For instance, SafetyLiftinGear's Electric Winch (available in 110 volt or 240 volt configurations) can be used as a winch with a pulling capacity of 800kg...or as a hoist with a lifting capacity of 500kg.
- Winches normally use dynamic brakes that are specifically designed to support rolling loads, not lift dead weights. The gears of a dynamic braking system automatically lock when pulling a load, but lifting a weight vertically can overwhelm the strength of this system, causing the load to slip and potentially damaging the gears.
- Hoists use mechanical brakes that are specifically designed to lock and support the load you're lifting. This system is far better suited to vertical lifting, and unlike winches, most hoists are fitted with load limiters to prevent you from attempting to lift a weight that exceeds the hoist's WLL (Working Load Limit).
Amerikanci imajo velik izrazov za naprave z bobnom in zajlami, hoist, winch, windlass, derrick, pa verjetno še kakega. Jaz si moram prav sliko pogledat, da vidim kaj je mišljeno. Se pa tud strinjam, da kar večinoma v svetu 4x4 imenujemo vinč, vitel, je namenjeno bolj vleki in ne dviganju. Jadralci pa svojimi počno oboje, vlečejo in dvigajo.
- markoter
- Prispevki: 645
- Pridružen: 02. Oktober 2009, 18:39
- Kraj: Radlje ob Dravi
Zej pa vključite še kak škripec ko se premika, takega, ki se ne pa izgube na premeri in trenjih kolutov,....
Si že videl kakega terenca s takim vitlom?
V filmu 'Bogovi so padli na glavo' je landroverja vitel potegnu iz grape in potem naprej na drevo. Tko, da se to dogaja
Ja, v filmu so šli tudi z deloreanom v vesolje. Pa ponavadi niti ni več kot 5000km prevozil brez okvare, ker je bil tok pokvarljiv.
V prihodnost so šli
Nisi še FF9 gledal?
A ni to Pontiac Fiero? Rdečih DeLoreanov ni blo ...
https://www.motortrend.com/uploads/site ... ero-77.jpg
o madona
... ker je ta tema močno zajadrala izven okvirjev naslova, in ker sem nemalo prispeval k temu, tukaj poziv za vračanje k izvoru.
Pri nas zima zgleda precej drugače ...
https://s9.mojalbum.com/17370239_300000 ... 053730.jpg https://s9.mojalbum.com/17370239_300000 ... 053731.jpg https://s9.mojalbum.com/17370239_300000 ... 053732.jpg https://s9.mojalbum.com/17370239_300000 ... 053733.jpg https://s9.mojalbum.com/17370239_300000 ... 053734.jpg https://s9.mojalbum.com/17370239_300000 ... 053735.jpg
... tako da z veseljem pogledam kakšno bolj belo fotko ter preberem kaj iz Slo zimske scene.
- Kristijan
- Prispevki: 1324
- Kraj: Goričko
Sem se peljal v DMC-ju, ima znanec. Zanimiv "rostfraj" voz, pač ameriški
Ne vem pa kako se v snegu pelje, da ostanem v temi
Vrecha, zakaj so pa te kvadri po pisti?
